Smar card door | SatelliteGuys.US
Smar card door
fordexpr03
4
Wisconsin
Smart card door
Does anyone know where I could find a replacement smart card door for my 322?
I have a feeling if they do not have one that's intact when they get the receiver back it will cost me the 500 dollars to buy a new one. One chance I don't want to take.
Thanks for the input!
I have a feeling if they do not have one that's intact when they get the receiver back it will cost me the 500 dollars to buy a new one. Once chance I don't want to take.
Ebay is about your only chance. If you have it somewhere, but it's just broke, glue it back on with some bathtub caulk. It's not your fault if it doesn't open.... ;) That caulk will peel off easy if somebody wants it off.
I see this a lot in the field. Don't sweat it, they won't charge you. I've seen them with the entire front panel falling off and it hasn't been a problem!
I can only offer an opinion, I have no first hand knowledge. Don't worry about it, I can't see them worried about that.
922 IP Address affect Sling?
Had to Cancel Dish Service ...
