Yes you can.tkorcal said:Is it possible to obtain new smart cards for used 301 receivers?
sfollenius said:The camid is the card serial # s00XXXXXXXX
Stargazer said:You can get a whole receiver for cheaper than what the smart card alone costs.
If you look the back of your receiver you'll see a label with the model and the batch idHDTVFanAtic said:Interesting...but if you buy a STB without a card, there is no way to have that.
In fact, it seems they want you to buy a new one instead![]()
technoguy said:If you look the back of your receiver you'll see a label with the model and the batch id
also the CAID and the main board id,ALL IRDS happens to have that.![]()
technoguy said:BTW you don't need to be a hacker to know this.
Limited time offer
