Snow on first couple channels | SatelliteGuys.US
tech99
Ohio USA
Time Warner Cable, Lake County Ohio
Philips Magnavox TV
All channels work OK. Then a few days later, channels 3,4,5, and 6 start to get snow. Channel 8 and higher are OK.
If I disconnect the cable and reconnect, the problem is fixed. Often I need to do this several times until the snow goes away.
After a few days, the snow comes back.
I'm thinking the connector must be OK, since it works for several days?
Any suggestions?
Sounds like a bad connector. You're getting it to make good contact by unplugging it and plugging it back in, but it probably doesn't take much to jar it back.
RIP Cruisecast
Trouble receiving Intelsat 9
