If the dish is solidly installed you could try a snowball? - hitting it might cause an "avalanche" and the snow to fall off especially because it should not have much moisture in it? I would hit it from behind if possible. Is there anything with length you have that you could tap it with?
yes , 2nd story , everyday Erie get more and more snow , it's unbelievable , and unfortunately i am disabled so i limited to what i can toFrom the news reports on the snowfall Erie received. I'd bet clearing the dish off won't be good enough, clearing the dish and the immediate area around it is probably more like it.
Where is the dish located, roof on 2nd story?
Yes, I wouldn't install a heater till its cleared, so it won't help THIS time around.How water from the garden hose.
Or a dish heater but by the time you install it, the snow probably melted
A water gun is the LAST thing you want to do...With the frigid temps, the water will simply freeze on contact, compounding your problem.i been without directv for about a week now because of snow, i can't get my dish to clear it off, and Erie Pa has been hit by record account of snow, what can i do beside of a water gun?
Yes.Shouldn't the directv app on a tablet or phone still work in this case?
Do they do driveways too ?to update mine mom, called Directv today without mine known and i am guessing they are coming tomorrow and doing something to clear the dish off plus a month free
Limited time offer
