Gently, with a broom if you need the reach, with your hands if not.What's the best way to get snow off the dish? I am afraid that I'm going to misalign it.
I just went outside and used a broom (gently, of course); everything's fine now!
Do a search for "PAM" - famous myth - the effect is that you have a bug-coated dish.The best way to avoid ice/snow on your dish is to spray it with a silicone based spray or you can use pam spray even to lubricate it so the snow/ice does not stick to it.![]()
Just get a garden hose and spray the Dish with water![]()
Limited time offer
