Solaris NFusion | SatelliteGuys.US
Solaris NFusion
twoway2
3
HI; Was using this receiver for FTA Stations and getting good reception .But accidental hit the " Initialization" button and lost everything in the receiver.
I cannot get the receiver back to normal so I can get my programs.
Any help would be appreciated.
"Initialization" is a factory reset, it's Nfusion's way of wording it. You'll need to start from scratch and set everything up again, no need to reinstall any bin files, just the sat settings and rescan for channels
Thanks for the reply
Could anyone tell me where I can get the "Factory Reset" for the receiver?
Factory Reset Info
Hi.Can any one tell me where I can get the "Factory Reset" info for the Nfusion "Solaris" receiver.
In your first post, you say you already hit the "Initialization" button, so it should be reset.
To help you get it set up again, we'd need to know what if any switches you have wired in, and which LNBs you have.
Of course, which bird(s) are you aimed at?
He may be asking for the factory bin or he may think there's a file or some setting that will restore it back to where it was. I PM'd him to inform him where to get the factory bin in case it is what he's looking for.
dishpointer obstacle questions
i need help to get c band whit a 4 footer offset dish
