Some Edision MIo Questions | SatelliteGuys.US
JFOK
1,105
839
Cape Cod - MA.
Hi All,
Looking for some answers...
I no longer need Simon Bolivar 78W in my satellite lineup. How do I delete this satellite from my list and will deleting it remove it entirely from my stb ?
Also, on some blind scans I've made, the result shows "Mexicana" with some sort of empty programming list. Anyone else get this and if so, whats the solution ?
Thanks in advance.
John
Hi Arlo,
Thanks for your response.
Hope your FTA system is operating to your liking.
I've heard of E-Channelizer, but was hoping there was an easier way to delete satellites with this stb.
Will look into your suggestion.
Thanks again,
John
Hi Arlo,
Thanks again,
John
Hope you do. Imagine how much work you'd have arranging a sat like 105. A channel editor allows easy changes.
And the ability to save it all if, for example you load a new image in a slot and have to start all over.
....' open lamedb, write to box'.....done!
Reactions: JFOK
