Some Hurricane Wilma Pics | SatelliteGuys.US
Not open for further replies.
what kinda crap service did you upload these on? I can't just click on a pic to view them?
How about attaching the pics instead?
But I take it you have your power back?
I wanted to upload the full size pics. I have a bunch that are down rezzed but I will post those later.
No power yet. running on a generator. They say we should have it in two weeks
Come on by and fix my dishes. I actually went around the neighborhood and found enough parts to get my dish 500 going!
your dish looks fine in that pic. Were those in the eye?
So it shattered in the second half?
some of them were in the eye. The Dish 500 just wobbled a lot and got loose on the skew adjustment so it bounces in the wind a lot. the bracket that attaches to the wall was bent so there was no way I could line up the dish. I found someones D* dish that had blown away and used the mounting arm from that for a temporary fix. The LNB was also full of water but is still working. My dish pointing at 61.5 is just gone, blew away somewhere.
You can tell which pics are in the eye by the light, within about 20 minutes of the backside of the eyewall passing through (which was the strongest part of the storm) we had mostly sunny skies and the temperature dropped about 20 degrees. My pool enclosure collapsed in the last half hour of the storm.
Looks just like here in central N.C. after Fran in '96, just more palm trees. :(
Best of luck, John. Keep the 110 running.
harmony remotes
Netflix Class Action Settlement
