some TPs missing on Echostar 7 - 119..Tried everything? | SatelliteGuys.US
AtlzBest26
Hi
I've got a SV-1000 with Super Dish (110,119,121). Its been installed very tightly and securely for 6 mos. I had all channels coming in fine before.
Recently, i started seeing some channels with no signal, i explored a bit more and found that some TPs on 119 are showing no signal.
Ive tried running a direct wire without a switch, flashed the bin file again, did a factory reset, blind scanned, re-scanned ...everything is still the same.
12239, 12297 in particular are showing no Signal..there where Showtime East, Food Network etc are...(LNB is set to OCP-DP, 12250, 22khz off, DiseqC to correct port...i see Echostar 7 - 119 locked on top right). i also dont have any custom sat files, custom anything except bin file.
So its not a problem with my settings overall since some TPs are coming perfectly fine..
Problem 2...if i change the LNB type from OCS-DP to Single and change the Freq to 11200 instead of 11250...some TPs come to life on 119! (but some are still dead)...
Can anyone comment what is going on? Do i have a bad LNB? All other birds are fine..tried without switch too..
Try subscribing to the service idiot instead of trying to steal it.
Your information has been forward to Dish Network security department per our user agreement.
Have a good day!
DVR rebates
Just Ordered a HD Dvr
