Someone from Youngstown OH please answer my question. | SatelliteGuys.US
ageism
95
Thinking of upgrading to hd receiver and can not make out for sure if the Youngstown locals are in hd. Did a search on fourm and found nothing in 2009 or 2010. Seems like 33 and 27 are carried by dish in hd however 21 and fox are not. The confusion is called 21 and they said that in the evening and the morning they are in hd. Is this true? Thanks.
DISH's updated (?) website shows only 33 (ABC) and 27 (CBS) as HD.
I'm in Northwest PA, but we're part of the Youngstown, OH DMA.
The HD channels 27 and 33 are only available on the 129° sat, so if you were like me with a 110/119/61.5 setup, you're out of luck.
I just use an OTA antenna with my 722k, and I'm a good 40-50 miles from the transmitters, and it works fine.
local spot beam feed
my distant neworks
