I have a real head scratcher here...
I had a hopper and 1000.2 dish set up at my house in southern oregon. Signal on recvr was in 50's which is normal in this area. About 2 mos ago I would start getting signal problems after dark...most channels other than the network spots would lose signal after getting either a 'HD signal loss switching to SD channel' or the opposite ' SD signal loss switching to HD channel'. And then the satellite signal screen would come up and it would start on ie 119 going thru steps 1 to 5, and then it would switch to 129 and then 118 and then X for satellite number and freeze.
The only way I could fix this would be to run a check switch and then all would be back to normal. and then it would happen again after a while.
I then took that same recvr and hooked it up in my rv with a 1000.2 dish on a tripod 60 miles away. Signal was 95% on 119, 70% or so on 110 and 129 with a birddog. The same thing happened at night but in the day it worked as it should.
So I had dish send me a new receiver the other day. I downloaded new software thinking that this would be the fix....but no! it did the same thing losing signal about an hour after dark. And once again I saw it looking at the end for 118.
So I am at a loss and need some advice please!!!
