Sonicview 360 Elite | SatelliteGuys.US
Sonicview 360 Elite
todrod
Eastern Kentucky
Hello, I have an existing Sonicview 360 Elite FTA. I know I would need a 36 inch dish, but will my reciever work for Glory star and pick up all they offer? I know that Glorystar doesn't offer suppport for my reciever, but as long as it's set up in the factory setting will it work? Also does the lnb's come with the 36 inch dish when buying it? Thanks for the help.
Yes your receiver should work just fine. If you want the full GloryStar set of channels you will need a GloryStar dish with the dual-4 degree bracket. If you want just AMC4 (101W) or Galaxy 19 (97W) then any 36" dish will work. Generally dishes come without the LNB.
Bob
any receiver will work. You just have to scan in the channels.
I use a Coolsat 5000 for the Glorystar channels (but the Geosatpro 200 is much easier to use for GS setups) ;)
The Church Channel
Join Us on SatelliteGuys Radio Show 3/2/2010 @ 8pm EST
