Is anyone else out there having problems with their Sonicview 360 Premier tuner? Mine is loaded with apparent software bugs that render it only partly usable. I'm running the latest (0105) firmware, and all the replies from SV support seem to be 'canned' responses, like "reformat your disk drive again", "reinstall the firmware", or "that isn't supported".
Here's my list of grievances:
1. The box will recognize an external USB disk when first connected, and can write to and read from it, but after some period of time it "forgets" the disk and gives 'incorrect format' or 'no disk' errors. This makes the box practically useless for recording, because when the scheduled recording time arrives it doesn't recognize the disk.
With some trial and error, I found that the sv360 forgets about the disk drive if it is tuned to a channel that fades out. Somehow a loss of signal triggers it to trash its internal memory. A complete power recycle cleans this all up.
2. After scanning 2 or 3 satellites, the box reports 'no memory' when doing a TP scan. A complete power recycle clears this up.
3. I got a Sonic Voom headphone so I could start listening to AC3 modulated sound using the optical SPDIF output. I can hear the sound for "normal" channels just fine, but ALL of the AC3 channels (PBS, Pentagon...) have no sound output. SV support tells me that these channels are modulated in a format that can't be decoded.
4. The time setting is screwy. If you leave the time setting to automatic, the time on the clock changes by several hours depending on which satellite you are pointing at. (maybe this is normal...). I have to point to an echostar sat and set the time to automatic then back to manual to set the time every time I cycle the power (which is often).
I learned from my research while getting into this hobby that most of these satellite boxes don't live up to their expectations, and I would still be sitting on the sidelines if I was waiting for the perfect receiver to come along. Still, it would be nice at least if most of its features actually worked.
