Sorry, But I can't remember | SatelliteGuys.US
dcavaiani
156
4
WI
Brought my SD and HD receiver up to camper. Hd works fine, can't get d12-100 to work, although I am getting some 101 signals with S-video connection to tv and that is selected on the TV. I have a true SWM 5 setup, and it worked last year for the SD, but ....
Here is an update - strange behavior: Brought SD box home and it works fine with SWM switch setting. Brought it back to camper and it is now working fine with the SWM setting. HOWEVER, NOW I am not getting a signal on the HD Box (which has the power inserter next to it (error 775)! Error shows on HD while the SD is working. UPDATE: Did an HD box reconfig and it is now working as is the SD box ...
Adding a C61K not purchased from Direct.
moving satlite from roof mount to wall mount.
