Sound issue G10R | SatelliteGuys.US
Sound issue G10R
Hotrodphil1
96
79w 87w 91w 97w 123w
Lost sound on:
11815V
7.234 SR
4128 video
4129 audio
4128 PCR
Sound keeps going in and out. Good show about Monsanto and their Patents on 11,000 Non genetically modified seeds. Also talks about the toxicity of their Genetically modified crops. Patents on nature were banned by the constitution, and need to be kept banned. Anyone else verify this sound issue?
Are you sure you're on G10? I don't have that transponder and I'm picking up "No Signal" trying to get it...? What is the Channel Name?
The transponder went dead shortly after I posted this information. I failed to pass on this information the other day. Funny this transponder carried a few channels on it. They All went down. Yes I was on G10r, not peaked, but at least 80% there.
The transponder is currently back up. Did I mention that I use a 10600 LO setting. So my box frequencies may be different than someone who is using a 10750 setting.
If you have a Standard LNB, then the 10.750 ghz LO setting on your receiver will match your LNB and give correct frequencies.
Anything else may work, but will have incorrect frequencies.
If you have a Universal LNB, then the 10.600 ghz (and 22khz ON) will match your LNB and give you correct frequencies.
From the specs the channel sounds like Peace TV, which I have ( with my LO-10750)
at
11965 ( 150 khz above your freq)
V
7242
vpid 4128
apid 4129
pcr 4128
We're pretty sure you should be operating with a LO of 10750 .
Special request from Turbosat
Looking for info on DirecWay DW4000 dish
