Special HR20-100 and -700 {CE:09:03} - 0x1B? tonight only | SatelliteGuys.US
Systems in this CE / Version
HR20-100 {CE:09:03} - 0x1B?
Windows of opportunity to download:
SINGLE NIGHT CE: Tuesday; October 30, 2007 11PM - 2:30AM ET
CE Probability: 95%
Be sure to monitor the threads and chat room to check on final availability
While you are waiting for the Window to open:
MUST READ AND AGREE TO: - The CE Rules, Faq and Tips Thread... Here
Please join "us" in the CHAT room, about 15 minutes before the window opens... and till... well to the last person turns off the lights...
http://chat.dbstalk.com
The Contents of the Release: (Differences based of 0x18a National Release)
  • Items from CE:09:01
  • Items from CE:09:02
  • Items from CE:09:03
Improved
  • Overall System Stability
  • Prioritizer Screen
  • Navigation to PIG (Picture In Graphics) removed. (Trick Play Still works), to improve interfacing with UI
  • Several user interface polishing and fixes
  • UPnP issue that certain networked devices could cause the unit to hang.
  • Recording Reliability
  • Improved interactive load time
  • Fix for playback stopping early
  • 02 - MPEG-4 HD PPV, Record Now-> Buy Later
  • 02 - Recording Defaults now part of OnScreen menu in Record Screen
  • 03 - Additional improvements to boot reliability with network connections
  • 03 - DoD- PPV Corrections
  • 03 - Interactive TV Updates that will improve Gamelounge
Updated
  • History list now includes conflicting program
  • AutoCorrect FF will not "correct" when STOP or REPLAY is pressed
New feature(s)
  • DirecTV on Demand
  • Keyword search finds category (eg HDTV or sports)
  • Left arrow mimics "BACK" when practical
  • Long channel name in search by channel
  • Ability to hide SD channels if duplicate HD channel with same number exists
  • Grouping of Search Results
  • 02 - Third Favorites List: Channels I Get
Notes
  • 03 - DoD will not be automatically activated; You will need to activate via the IWANTMYVOD keycode method
Note to other sites and users of those sites:
You are permitted to copy this CE Announcement in it's entirety (including this disclaimer) without modification so long as you provide a clickable link to DBSTalk.com.
HR20-700 {CE:09:11} - 0x1B? Announcement
  • Items from CE:09:04
  • Items from CE:09:05
  • Items from CE:09:05a
  • Items from CE:09:06
  • Items from CE:09:07
  • Items from CE:09:08
  • Items from CE:09:09
  • Items from CE:09:10
  • Items from CE:09:11
Improved
  • Stability
  • Several user interface polishing and fixes based on CE reports
  • DoD: Misc. Reported issues fixed
  • DoD: Performance improvement
  • User interface polishing
  • DoD UI: Restored CHANNEL UP/DOWN in the Homepage Left Menu.
  • DoD UI: Homepage "tuning" fix for consistent prevs channel
  • DoD UI: Added "On Demand" to quick menu after "My Playlist"
  • DoD UI: UI Polishing/fixes
  • Caller ID (no specifics on what)
  • UPnP issue that certain networked Cameras could crash the box.
  • A plethora of fixes to issues identifed in the previous CE's
  • Several UI Fixed and Polishing
  • Fixed the CE Introduced issue with items in the ToDo List, but ultimately not recording
  • DoD UI: "More VOD" in ever page
  • DoD UI: Misc. Items
  • DoD: Corrected - Not being able to resume playback of a currently downloaded program
  • DoD: Corrected - Listing performance
  • Additional Stability fixes
  • Missed recordings
  • Tuning issues
  • Channel info not updating with record icon
  • Channel banner issues
  • Active main page loosing highlight
  • DoD: Deleting active DoD item from Playlist taking long time
  • DoD: Unable to delete program if it was paused on the queue
  • DoD: Fix guide paging down when graphic row appears
  • Improved remote control accuracy
  • Remote Control sensitivity returned to 0x18a code base
  • Additional Stability improvements
  • Improved boot reliability with network connections
  • 10 - Additional improvements to boot reliability with network connections (This update did not make it to 0x1B9)
  • 10 - MPEG-4 HD PPV, Record Now-> Buy Later
  • 10 - Recording Defaults now part of OnScreen menu in Record Screen
  • 11 - Additional improvements to boot reliability with network connections
  • 11 - DoD- PPV Corrections
  • 11 - Interactive TV Updates that will improve Gamelounge
Updated
  • Unwatchable content is no longer kept in the disk
  • Exiting FF via RW or PAUSE then Play, will no longer AutoCorrect
  • Modem will drop connection when phone is phone is picked up
  • DoD: Minor UI polishing
New feature(s)
  • Caller ID for Type 2 (aka Call Waiting, off-hook, ect); Caller id reverted to 0x18a version
  • Start/resume to manual
  • Support for Remote Booking
  • DoD: Pressing INFO when over the DoD channel goes directly to the "ALL" List
  • 10 - Third Favorites List: Channels I Get
Notes
  • 11 - Yes, this is a continuation of the same cycle (even though 0x1B4 is national now
Thanks to Earl at DBSTalk.com
Trouble??
I have downloaded 2 prior CE's in the past without any difficulties. Tonight it appears to not be working anyone else having problems??
So much for 95%. :)
Oh well I guess I can go to bed now. I was actually staying up to get this CE since I wasn't around the grab the latest over the weekend.
HR20-700 {CE:09:09} - 0x1B?
DoD HD programing soon?
