Specific sat. locations for aiming... | SatelliteGuys.US
Sentry
57
Huntington WV
Greetings -
DirecTV install recently with newer style dish. Having trouble picking up one satellite with my locals on it. (Charleston/Huntington) Not sure which of the three it is.
Trees are in the way and I would like to find out which trees to trim by using a compass. Signal comes and goes but as leaves start to grow, it will be worse and worse. Don't want to cut down anymore than I have to so I would like to find location of that specific satellite rather than just the general location of all three.
Could someone tell me where those are for my Southern Ohio zip code of 45619?
Thanks!
It should be much easier to move the dish to a better location than to cut the trees, but your locals are on 119.0w DTV 7s and your PhaseIII dish setup is:
Azimuth: 225
Elevation: 37
Skew: 61
Thank you both. Moving Dish is not option in this particular case. Mounted at highest peak. Tree cut should work, that website was very helpful to me.
Thanks again.
New DirecTV DVR??
D* now downrezzes all 1080i channels to 1280
