splice cable dvr 522 receiver | SatelliteGuys.US
cxm475
philadelphia, pa
I want to move my receiver to the other side of the room. What materials will I need and where can I get them? I want to do this myself to save cost. I need some cable and then splice it b/c the technician didn't give me any slack with the initial install.
I'm new to satellite signals so bear with me. Is it just a standard coaxial cable?
THanks
Chris
well if you have a wall plate just connect the coax from there to your receiver
remember get rg-6 coax
and if its not a wall plate make sure u get high frequency barrels you will know which ones they are they have the blue center
oh and you can get those materials at any hardware store ie: home depot, menards, lowes etc . . .
Online DVR Programming
625 locked up on guide
