Splitor question? | SatelliteGuys.US
Splitor question?
hzhao
280
With DDP44 and splitor, can you connect two receivers to splitor? or the splitor only works with single receiver with two input?
Thanks in advance.
Thank you to point that out :-) I do mean separator. BTW, is there such splitor exist for satellite signals?
The short answer is yes. However, it's application is extremely limited.
ALL it can do is convert a DISHPRO Single LNBF into a Dual, or a Dual into 3-4 feeds. Note that I said a Single - NOT a Twin or a Quad, or the output of a switch, or anything else.
HD locals on Dish?
2.80 screwed up my 'subscribed channels' list.
