Splitting Joey | SatelliteGuys.US
Splitting Joey
you can back feed a picture signal along a the same line you use for satellite signal using a diplexer are you thinking of a setup like this 2latwrn.jpg
Well I just did some further searching and found that the MOCA network doesnt like diplexers so that idea is a no go.
FireFighterHill said:
you can back feed along a single line using a diplexer are you thinking of a setup like this <img src="http://www.satelliteguys.us/attachment.php?attachmentid=78283"/>
Not with Hopper/Joey. It would interfere with the MoCA signals.
Sent from my iPad 2 using Forum Runner
It was confirmed (by 1 user anyway) that diplexing OTA before the node causes MoCA issues. Not sure if that is the case with everyone or just that 1 user. 1 user is a small sample size but I don't have the need/patience to test it for myself. That still leaves the question of whether or not a backfeed from an RF modulator diplexed before the node would give the same results. Probably yes, but we'll never know until someone tries.
dish guy at door
Which hardware (dish/LNB, etc.) for new service is needed?
