Splitting TV signal (receiver) to a new TV | SatelliteGuys.US
sbsi
451
Currently, I got 4 TV hook up, 2 (TV 1) w/duel receiver, 2 (TV 2).
Is it possible to split one of the signal on the receiver to a different TV, 5th TV?
I look at the back of the receiver and connection. I see a Dish Network or TV splitter with two wires connected to the receiver and one wire connection to the TV.
How bad will the picture quality be or no major difference?
It is best to split the tv2 cable. If you have a diplexer on the outside of the house or whatever you can split where it has the AUX port. TV2 will have to be on the same channel as the tv2 are now. And it will see the same picture as well.
You can split tv2. On the back of the receiver there is a tv2 distribution port. You can put a splitter there or wherever the diplexer is located. If you split at the diplexer, put the splitter on the "UHF" port of the diplexer. It's easier to split tv2 because you can then use the tv2 remote at the split location seeing it's a UHF remote. Much easier than splitting tv1 which most times has an rf remote. Just be sure to use a good quality splitter to decrease loss.
Adding An EHD To My 722K
Yellow Screen
