Sports mix 206 works | SatelliteGuys.US
thesapster
21
I don't post often and I did a search first and didn't find a solution. So I go to espn 206 and get the 711 error but I can see the channel on the sports mix channel. Any suggestions or help would be appreciated. Thanks in advance
Check 99CA transponder 23. What's your signal strength there?
That explains why you have no ESPN. You could have a bad lnb, loose cable, maybe an alignment issue. What are your signals on the other transponders?
All the other sat signals are good 70's to high 80's. Checked all connections I am thinking lnb. Also I am in Alaska thanks for the info
Being in Alaska you need a bigger dish than normal. Do you have the larger one?
At&t's future plan for Satellite service?
Shut off my service, now...
