sportsmen channel c-band 121 | SatelliteGuys.US
turbosat
9,003
82
Oneonta,AL
Rediscovered this channel on c-band tonite, can't seem to get the audio right, only coming out half the speakers....and can't get the dolby to work either. Anybody got this one with audio correct? If so, how'd you do it? Thks
I checked it with TSReader. The mpeg audio pid 36 only has audio on one channel. The AC3 pid 44 seems to work fine though.
Thanks! The ac-3 wasn't working, I may need to adjust the skew to get a better signal, forgot to look at that part last night, it seemed like a stable lock though.
edit: I found out the AC-3 didn't work because I had the optical cable plugged into another receiver. Works fine now with audio pid44
TBN DCII Mux
Scroll on Viacom owned channels
