spring hr20-700 update | SatelliteGuys.US
iceturkee
DINFOS Trained Killer
7,392
146
daytona beach
just got home from running errands and noticed both of my hr20-700's received the latest national upgrade this morning. i believe this was the cutting edge release of about a month ago. i love the lighter menu colors. i'm sure it will take me awhile to discover everything else too!
So, where is the list of "fixes" or changes included in the national release? I don't see a thread for it...unless I am staring right at it and not seeing it!
DirecTV normally doesn't publish a list of what's fixed in their software releases, since when you talk to a CSR there's never anything wrong with the software;)
About the only thing you can do is check the D* Cutting Edge section over at DBSTalk.Com and try to piece together what was fixed or new features were in the prior cutting edge software releases.
What you are seeing now, was discussed in the "Cutting Edge " previously, as the C.E. user get first dibs at it (anyone can be a C.E. 'er, just undrstand the situation prior to doing it).
The C.E. program is basically a Beta test that D* has allowed subs to get early software updates, in exchange, we post our findings, good or bad and that gives D* more info to work with. (D* has it's "internal" beta testers as well) . They in turn correct any glitches that are found, once they are happy with the results,,thay generally will release it to the public as the "National Release", the one you received. :)
If interested in doing the C.E. stuff, browse the threads and you will find info as to how it works.
Jimbo
B-band Conv/dvr Issue---chan 94/95
6 lnb solution?
