Spring is finally here. After sitting inside all winter planning your projects for when things thaw out, what are you working on?
I had some cable runs that were sub-optimal, running past the entry to the house, out to my switch box and back the same direction. I also got rid of lots of buried conduit and started using conduit above ground behind bushes etc... Much easier to work with.
Here is where the box was, dark and behind some bushes.
Now I moved it to a spot near were the cables enter the house, and up high where I can see inside it.
Only have two dishes rewired so far but they are the important ones, 97W Ku and 101W C.
Three Zinwell powered multiswitches, two Chietas hidden behind the two Amiko diseqc switches.
I also recommend marking the incoming cables. Lowes has some stick-on numbered cable lables, they're great.
Here is a peek inside:
This picture shows the layout of the powered multiswitches. The framework and bracketry were all custom made by me last year, serves as a ground buss also. This location also puts me closer to the electrical service ground rod.
Bottom view, lots of 4-8mm PG-9 connectors. I also believe in service loops, not pretty but if you need the extra slack one day, your going to be glad you have them:
Here is where the power supplies are:
Here is the schematic:
Right now it is setup for 4 receivers and 6 LNBFs, but expandable to 8 receivers 8 LNBFs.
As far as the parts:
The switch box is a BUD Industries NEMA box, notice the nice gasket it has in the picture above. BUD makes some great outdoor boxes.
Amazon product ASIN B005T57PK4
And the smaller remote power supply enclosure:
Amazon product ASIN B005T57OLY
And the 4-8MM PG-9 connectors. These are a must have for any outdoor coax application:
Amazon product ASIN B00EZ9UBRO
Labels are a must when dealing with lots of coax:
I still have more work to do in re-cabling the other dishes, but the fact that spring has sprung and I am able to start is a move in the right direction. I almost forgot, I got my 10 foot Winegard planted a few weeks ago too. http://www.satelliteguys.us/xen/threads/dish-id-help-needed.342888/
