st.louis hd channels. | SatelliteGuys.US
russ222
98
wisconsin
does anyone know which sat they are on .the chart i have says d10-103w trans 15&23 i get 0son 103s/na on 103cb/84&91 on 103ca so which one is 103w?
103s is the one you should be looking at, because those are the spotbeam transponders for the satellites around 103w. You are correct that St Louis HD locals should be on tps 15 and 23.
I made a chart to make it a little bit easier to see which cities you should be seeing on each transponder.
Hr-20, can I simply add this SATA drive I have laying around ?
tailgating with Directv
