Standard Directv Receivers (D12) and Vonage | SatelliteGuys.US
eldondee
19
Hello,
I recently got vonage and noticed that my D12 receivers are unable to successfully connect with Directv. In the calls log I see that the receiver is indeed making the daily calls to 2 toll free numbers, however when I called DTV tech support they are saying that the calls arn't succesful. They walked my throught the process of adding *99 Prefix in the receivers but nothing seems to change.
I contacted vonage which ran tests to diagnos call quality and other stuff but no luck. The techs at vonage even have me disable call waiting but to no avail.
I did a thorough research online and saw many posts with different sol.utions but all those seems to be directed at tivos/dvrs. I tried them however with no luck.
Can anyone help?
PS I tried several variations of the dial out prfixes which includes:
*99
*99..
..*99
,*99,
and many others were tried.
Does it really matter all that much if they can't call out? D* doesn't care, & other than loosing onscreen caller ID, the only other thing you loose is remote control PPV ordering - but you can order it for free online & it goes to ALL your receivers at once.
Yes, I agree. Thanks But I am the type who wants to have everything working the way it is supposed to. I kmow of people who have no problems getting this to work. What can my problem be.
Going way back, I had trouble with early Hughes receivers if there were any telephone voice messages waiting. The receiver would check for a solid dial tone, detect beep-beep-beep-beep-beep, and determine it to be "no dail tone".
Miami/Ft Laud HD locals sat/transponder
DVR R15 turns tv off and on
