Standard LNB/Universal LNB/SG2100 | SatelliteGuys.US
vicdiaz
26
Trujillo Alto, PR
Hi,
Is it possible to have a setup comprising a fixed dish with a standard fss lnb and a motorized dish with a universal lnb, both accesed and controlled by a single receiver???
I had a fixed dish at 85W (for sports feeds) tapped into the motorized setup with a diseqc switch...worked fine
Thanks for the replies!!! I wasn't sure on how to connect the switch (before or after the motor).
Some tweaking to do next weekend then!!! ;)
No problems adding a fixed dish to a motorized setup (or vice versa). I have had that configuration since the first motorized dish I installed in 2005. My very first FTA dish was a fixed 1 meter Channel Master (at the time on G-10R for the Equity channels, which are now sadly gone). That same dish is now on 125W, and is connected to the same switch as one of my motorized dishes.
How To Fix V Box III F2 Error Message?
Looking for guidance!
