Starband Change DNS - Telent or Clear CMSOS ????? | SatelliteGuys.US
  • Thread starter Thread starter phpinfo
  • Start date Start date
  • Replies Replies 0
  • Views Views 3K
phpinfo
294
USA
Months ago, I was able to manually enter DNS servers in my computer and in my router (OpenDNS). It was working great, but now the Starband DNS servers are the only ones that can be used.
I have tried to manually enter them, tried using a static IP with manual DNS servers. Nothing works. I can't get back to using the OpenDNS servers.
Does anyone know the Telnet password? And is there a way to enter new DNS servers? - I tried the Skymanage password, but that did not work.
- I noticed that the board has jumper bins. Would there be a way to clear the memory using a jumper, then manually enter a static IP (using the current assigned Starband IP) along with DNS servers, then hook the modem back up and force them to take?
In short, does anyone know the Telnet password to the Gilat Skyedge IP modem
and
Does anyone know what pins to jumper to clear the memory.
