Starband Chimney Mount? | SatelliteGuys.US
drdroo
1,195
Bangor, ME USA
I was looking online for a chimney mount to mount a 1 foot microwave antenna on and I found this Starband Chimney Mount that looks really well designed. However, I can't seem to locate one to buy.
Does anyone know who actually made the thing and perhaps a model number? It seems to use a ratchet to install and seems like it would be easier than the usual V bolt setups.
I found the manual for it here -
http://training.starband.com/newPDF/ChimneyMount.pdf
Thanks in advance.
That is probably an Andrew (now ASC) part number. I don't see them available from Starband anymore. Might find one from Tessco or one of the other distributors.
Good Luck, Eric
Hi Eric -
Thanks for the heads up. I have a Tessco account so I'll go digging in there. I'd rather use one than one of the Channel Master deals, but if I must, I must.. :)
