Starchoice 75cm dish instructions? | SatelliteGuys.US
Mat
5
Got my gear from kusat but there weren't any instructions. I can't figure out how to attach the dish to the mount. The mount has a circular "plate" that seems to fit exactly into a recessed area on the back of the dish.... can't figure out what hardware to use in the bag of bizarre parts that came with the dish.
Tnx for any help.
Mat
I just set up a 60E dish ,which i think is slightly different but I thinh basically you need to set the dish so it can rotatate on a 'skew'. so I think 2 bolts go through the front of the dish to allow it to skew.
you will get good advice here so hang in there.They helped me set up my whole system. Good luck.Sorry I could not help more.
thanks for the hint. I have emailed kusat and asked them for instructions. I have an installer coming over tomorrow and I am hoping that this dish is similar to other US dishes and that he will have no problem figuring it out.
There will be lots of extra parts if I try to do it...
Yup, did find the link at kusat -thanks.
I ended up calling in a pro, and it was not cheap. But I am getting signal strength in the 90's and signal quality in the mid 80's. Now I have to wait for the broker to get back to work before I can actually get to see something other than diagnostic screens.
Thanks for the help, folks.
You didn't miss much of a game last night. Kelowna was worn out from their double overtinme game the night before and ran out of steam half way thru the first period.
At this point, I would be happy to watch a bunch of old women play.
I called my broker and she will have me activated in time for the 7:00 game tonight. I can't wait...
