Starchoice DSR500 | SatelliteGuys.US
Starchoice DSR500
ToUgHsPot
60
Every single day I have to reset my DSR500. Is anyone else out there experiencing this problem??? :mad:
Are you turning it off every night to get the new 78 code? (Check current version in system status. After downloading, a hard boot (pull plug for at least 1 minute) may be required to flush the old code.
I always turn off unit every night allowing it to be in stand-by mode to accept updates. What is the latest current version??
what is the current version?
If you go through the system setup menu you'll eventually see a screen that will give you current version and target version of software. The current version should END in xxxx.78 (78 is the extension) and the target version should be 0 or none.
