Hey all.
I now have two StarChoice Lnb's and would like the differences and capabilities between them explained for me a little bit further..
plz
The first LNBF came with an older 25.5-W x 27.5-W (inches)dish, and has two F-connector outputs on the back (FYI: Neither of these LNB's are the old beercan style ones).
The second LNBF came with a newer 30-W x 17-H dish (approx-I am guessing) and has four F-connector outputs on the back.
Now I know that they are linear output and that is what FTA is as well. - Thanks to Iceberg for the info...
My further questions are:
What exactly are the outputs outputting? On the 2 output LNBF is one the Horz and the other the Vert signal. If so, then what's with the 4 outputs on the newer LNBF?
Or do each of the outputs send both the Horz and Vert signals? - I hope...
Which begs the question, how many Receivers can be hooked up to these LNB's? Would I need a switch of some type?
And finally, what should the low, low/high settings be set to on an FTA receiver for these LNB's. I do need to know these, yes?
I am sorry if all these questions have been asked and answered a million times already...
Thanks All.
Thanks All.
