An, of course, put them on 129 where many of us can enjoy the drop-outs too...
I don't have any problems with drop outs.
Check your line of sight or maybe your Dish is not "tuned".
The Illusionist with Scarlett Johansson will be in HD on Starz.
Dream On!!!! It took *E a very long time to add StarzHD, what makes you think that they will add these new channels as soon as they come out? I would not hold my breath.
I wish she was in this movie, but it was Jessica Biel (who's also not bad).
I have to agree with Swanni on this one...the only place you're going to see these anytime soon is on D*.
Although I am not as far north as Washington, I'm pretty close (near Oregon) and getting 80 on Transponder 30 (ESPN2-HD ) with:Even a 1000.2 won't fix the drop-outs here in the NW, as Chuck said: the problems here with 129 are severe and well-documented...
Then it sounds like you should go with the Dish 1000.2 which gets better signal on 129 than the Dish 1000. $99 from stores in the links above, if you can't get Dish to upgrade it for you due to problems.Oh, I've looked at a 2-dish solution, several times, and the problem is I don't have any other location to put another dish, except on the roof, which won't work for me.
Thanks though.
Limited time offer
