Station Zip Codes | SatelliteGuys.US
Station Zip Codes
Sadie
220
Nova Scotia
Thought this list of station zip codes might be useful to others
I used the info to build a program guide using Zap2it, I believe its easier with TitanTV, however Zap2it offers local programing for Canadians and the ability to set all time zones.
Its also possible to convert the data into a XMLTV file for use as an EPG in various software that uses the standard.
AMC 21 PBS Stations, a few local programs differ
KUSMDT zip 59716 PBS MONTANA
WGBXDT2 zip 02134 PBS World
WTTWdt3 zip 60625 PBS Create
WGBH HD 2.2 zip 02093 PBS HD East
Galaxy 18 Equity Transponders 11720 and 11800
KARZ zip 72201 My TV Fox
KBTZ zip 59731 FOX
KLMN-GRMT zip 59401 FOX
KMMF zip 59804 FOX
WMQF Zip 49855 FOX 19 ch14 Charter Comm Northern Michigan University - Cable (Marquette)
KCBU zip 84043 AMGTV
KDEV-LP zip 82001 AMGTV use KCQK
KEGS zip 89501 AMGTV use KKRI LP?
KQUP zip 99201 AMGTV
KTVC zip 97407 AMGTV KTVCDT
KWWF AMGTV Not found maybe a sub carrier of KWWL zip 50701
KFDF Zip 72901 THiS TV KFDFCA
WNGS zip 14202 ThiS TV
KKYK zip 72201 INDEPENDENT? This TV
KATV zip 72203 ABC
WPXS zip 62864 INDEPENDENT
KPBI-AR Zip 72901 MY network KPBICA
KWBM zip 65615 MY Network
WGMU Zip 05401 MY Network WGMUCA
KKTU zip 85701 MyTV ABC?
All over the air stations except WMQF
This list is from early February and is is continuously changing, particularly network affiliates, I believe WGMU is now defunct.
Sample TV guide page
I have posted a 'how to" for creating a Zap2it program guide here.
Its illustrated so the page is quite large for those of us on dial up around 400K.
Let me know if something isn't clear.
Sadie, thanks for this, it takes out a lot of the head scratching.
Yes Sadie:
It took me about an hour from start to finish, but I actually got it done..It works really well once you get the hang of how to do it..Only problem was having to use guesswork on a few channels because of Call Letter/Network changes recently, but the Zip codes were a big help. Now all I need to do is put the channels in order according to my Fortec Dynamic. Nice thing about this is, once you get the intial setup done, you can add more stations in just moments as you add more satellites to view..
Glad it helps, that's what this site is about.
It might be an idea if people find any new, better or not working zip code/station combination to post them here. It will save the next guy a bit of time
KUSM is a better match for PBS MONTANA it's at the same zip code 59716
I notice this week while PBS is fund raising, most of the fund raising shows are replaced by something else on satellite (except Montana) the rest of the schedule appears correct.
The wife's gonna like that she can look up locals with zap2it. She was annoyed that CSI came on at "a special time" an hour later so people wouldn't miss out on their American Idol. Now we'd know in advance.
G18-Several Spanish Channels-Black Screen
where's the decimal point
