STB features I would like... | SatelliteGuys.US
VegasVoomer
672
45
Las Vegas
Clock displayed on front.
Being able to edit Program Planner for multi-days.
Jump ahead 24 hours on the Program Guide with one button.
Search feature.
Caller ID that works.
. Ability to download program guide in 1 minute
. Ability to change channels without screwing up the program guide download
. No lockups
. Have the other program guides start with the currently viewed channel, like it does with the all-channels program guide
. Have the box remember setup configuration settings after a reboot
Be able to channel up/down in the Surf Bar and not have it revert to current time.
Don't reset all of the Program Planners to Remind when the box is reset.
Make Power On be the default for the PP.
Use the Favorites List when scrolling up/down using the Surf Bar.
Be able to punch in a channel number while the Surf Bar is displayed and have it show that channels info and not change to that channel.
Don't make the Surf Bar disappear after 5 FREAKIN SECONDS (that one really irritates me).
Have more than 1 Favorites list.
Faster EPG download.
voom need to add religious channels
Omigosh...I signed up! It's the Forums fault!
