STB Health Lite still displays Orbital 129 after move to 61.5 | SatelliteGuys.US
pomona
42
3
Hello,
Redirected my 500 from 129 to 61.5 a few weeks ago. Receiving signal fine.
LNB drift detected on 119 (e -6) (superdish)- still getting signal no issues yet.
Noticed under STB Health Lite under Orbital, 110, 119 and 129 is listed (all zeros for 129), but no 61.5. This is even with a new (refurbished) 722 that I swapped a 622 for just this week.
Check switch and system info confirm 110, 119 & 61.5. Just curious why 129 is still listed under orbital, but no 61.5?
Most important sat config for now - later after Ciel-2 replacement they probably will change it, but unlikely.
Those three sats are main cluster for Dish. Perhaps EA setup will have the changes in a future and will show 61.5/72.5/77 sats in that page.
Hello,
Clear the satellite reception martix..
Here's how you do this...
Disconnet the inbound cable from the back of your receiver(s)...Run check switch....The result will be "no switchbox detected"..Then reconnect cables and run check switch again....
thanks, already cleared matrix many times- when I switched from 129 to 61.5 and the new receiver shouldn't have even detected 129...so it must list those sats as default?
Smith, P. Most important sat config for now - later after Ciel-2 replacement they probably will change it, but unlikely.
New 722 but SD recording time is lower
VIP 211 Reboot
