Sticky nav bar | SatelliteGuys.US
Sticky nav bar
Not open for further replies.
TheKrell
A mighty and noble race originating on Altair IV.
39,085
47,110
Fairfax, VA
I'm on Satelliteguys 1.4.2 and my formerly sticky nav bar is no longer sticky. (I didn't try try the "no sticky nav bar" version of 1.4.2.) What happened?
Still working. :)
As I work I am working in the Dark Style since most do not use it, so I dont screw everyone up to bad as I am working on things. :D
Patch applied but still not working correctly...
Another bit of weirdness with this, I noticed this last night.
I'm looking at New Posts, when I scroll down the page the nav bar is sticky but it is being overlaid by the white fields for 'Get Our Apps', 'Satguys Radio' and 'Help'.
Style is SatelliteGuys 1.4.2 and I'm using FireFox 34.0.5
Bump.
Am I the only one experiencing this? It makes the sticky nav bar pretty useless when viewing a list of threads.
No issues here in testing. And no one else has reported anything. I would try clearing your cache and hopefully that takes care of it. :)
Cleared cache. No change. With this version of FF at least, the Satguys Radio and Help fields wrap to the following line if the browser window is not wide enough. Those fields than overlap the fields on the next line.
The only thing I can guess is you are running your screen at a low resolution causing the other items to get pushed to the next line. I am also guessing that this update fixed the logo not showing in the nav bar and that logo is pushing things over as well. I have removed the Chat room and Calendar links which should have helped with that. :)
Here, hopefully :), is a screen shot.
[GALLERY=media, 30]Satguy Upload by klang posted Dec 18, 2014 at 12:56 PM[/GALLERY]
Screen resolution is whatever is standard for a 27" iMac (non-retina). I did unzoom the Firefox window one click which seems to have stopped the wrapping. Thanks.
Reactions: TheKrell
Feedback Requested
Search limit ?
