Still haven't found... | SatelliteGuys.US
Robroyrogers
7
2
Nashville
I have looked everywhere and can't find the answer to what I feel is a simple question. I have a dish 211k receiver and a dp plus 1000.2 dish with a A229a1 Lnb. I am only running 1 receiver for tailgating purposes. There are 3 coax' coming out of the Lnb and only 1 slot for a coax on the receiver. What do I need (if anything) to hook the 3 outputs to the 1 input? Or can I just run one coax from the dish to the receiver.
Seems like a simple ?? But dish support told me they did not know the answer.
Hello, as HIFI has posted, you will only need to use one of those ports as the signal is stacked, the port should not matter.
Reactions: HIFI
Hopper 3 and 4K Joey - Switching Locations
Hopper 3 HD/EHD Questions
