Stop Recording on 722 | SatelliteGuys.US
jrv331
109
6
NE Ohio
I use record plus and set it to record programs on tv2. I set a timer for a program and once it started recording I tried to stop/cancel the recording, but could not. I was trying to do this from tv1 using that remote. I found that if I go to tv2 and use that remote I was able to stop it. Is there anyway of doing this from tv1?
John
Method 1: Make sure you are on the tuner recording the program. Press the 'Stop' button, then answer 'Yes' on the pop up. (This method does not work if you are watching the program from the other tuner).
Method 2: Press the 'DVR' button twice, highlight the program in question, press 'Select' button, press the 'Stop Recording' button.
Take your pick.
Delete Timer
Menu > 7 > Select and choose (the program you want to stop recording > Timer > Delete
Problems with Charlotte HD Locals
Dish is NOT the only one
