Receiver is a VIP211, when doing a checkswitch, I get something along these lines...
below images are using Legacy LNB's on 110, 119, Diseqc switch.
Originally for troubleshooting, I swapped out my living room receiver for the new receiver to test, this was on my new eastern arc 1000.4 dish, DPP w/ the internal switch, and I got a similar screen, only one port seemed to be good, and if I remember correctly, it said SWAJ for switch type on that.
Another strange thing I noticed when pointing the 500 w/ this receiver, that it would seem to randomly hit a signal for about 3 seconds (would not fluctuate, but frozen) then would loose the signal, immediately after would pop up saying "scanning for satellites" and reset all the info, including the signal meter goes back to 0, the zip code, transponder, dish type, and target satellite would reset to default. The box is brand new and just got my new smart card installed. The common denominator is the box, as my other VIP boxes work w/ the switches on both the 500 & 1000.4. Is my box junk or am I missing something? Going on about 3 days of troubleshooting and still nothing. what can I try? Please help!
