I have a brand new PVR510 and it is suffering from the strangest problem. If I turn the unit off and leave it off for more than say an hour, when turning it back on, it comes up with a message saying aquiring Satallites. Unfortunately, it never aquires them. If I go into the Menu to check signal strength it shows 50%.
If I do a Check Switch, it will go through the 38 steps and then come back fine (120 signal stength). But again, once the power is turned off for more than an hour, it loses the satellites and I have to do the Check Switch all over again.
This makes it impossible to do timed recordings.
Yeah, some would say just leave the thing on 24/7, but that isn't the answer since something is clearly wrong. My other receivers (5000 & 6000) are fine. I have Legacy LNB's, could that be an issue? I tried switching out the coax cable. No change. The 2800 I used to have in the bedroom never had this problem.
E* couldn't figure out what to do so they want to send me a new one to swap out.
Opinions?
EDIT: Just realised I should have posted this in the E* DVR forum. My bad. Scott, please move it if you can. Thanks.
Opinions?
