Streaming from Azbox to PC | SatelliteGuys.US
putney
854
6
St Louis, missouri
I've been playing with this for a hour or so. I thought I'd share since some are interested.
I am using version 0.9.4295. The UDP stream has been present since v. 0.9.4283
It's VERY spotty. It doesn't work with all channels.
In Azbox when watching a channel, press "MENU" on the remote and select "Streaming".
Leave IP and Port (for now)
In "Duration" put the time that you want in minutes. To select 0 minutes select "not defined" and you will have streaming without time limits.
Open VLC. File/Open Network
Click 'Open RTP/UDP Stream'
Select: UDP, Multicast, IP(from Azbox), Port (from Azbox)
OR
On a PC, open the m3u file with VLC
You should have the streaming working in VLC with a PC in about one minute.
I've tried other ports with no better performance. Azbox will not let you enter a full 16 number IP address.
Woking better today (wife's not online)
It seems to work better with standard def channels; bio, history.
It runs pixelated for a minute, then seems to level out. I wish there was a buffer setting on the Azbox.
Woking better this morning (wife's not online)
[update] Just added new bin that addresses streaming. Can't get it to work right now.
Anyone Here Bought An AZbox Premium Plus
hdmi not working
