Stress on motor / where to park dish? | SatelliteGuys.US
iafirebuff
4,394
8
Waterloo, Iowa
Just wondering - is there less stress on the motor when you are at your ts position than when it is at say 30w? I was thinking maybe I should not leave the motor parked on the far ends when not in use? Does it matter? Thanks for any input!
if its windy it will matter and can knock the dish off kilter if not bolted down properly. I usually leave mine on TS at night but have been leaving it on G10 too. I think as long as there isnt insane winds out there you should be OK
So - David Good was really Tim?
SuperDish Feeds/LNB
