Stretched SD channels | SatelliteGuys.US
dbldhd
4
Hi,
I just got Voom installed and love it. However I have a problem. I am using the DVI connection and the HD channels are great. But the SD channels are over-stretched. I can't see the surf bar and the picture is cropped. I've tried changing the installation settings but nothing seems to work. I like the fact that my screen gets filled, but don't like the over-stretching. In comparison, when I use component video, the SD channels are fine and fill the screen appropriately. I just invested quite a few dollars in a DVI switcher and cable and so would hate to have to go back to component cables. Please help. Thanks.
Sounds like you have your Voom receiver set to force 1080i all the time and your TV uses a "full" aspect ratio when it sees a 1080i signal. When it gets a SD signal, it'll stretch it to fit.
If this is the case, reset your receiver to pass through the native resolution of the program. Punch the red button under the door until all light bars illuminate.
Has anyone found out why they charge sales tax?
Voom Wasting my time...
