Strong feeds | SatelliteGuys.US
Strong feeds
chicago30
14
Can anybody provide me with strong feeds for PAS 9 at 58, PAS 3R at 43.1, Intelsat 903 at 34.5?
Thank you
PAS9 you need a Universal LNB to pick up anything on it
I903 has nothing on it that faces this side of the globe
Strong or weak feeds depend also on your location. Best if someone close to your area could verify the signal from the satellite.
Also, what size dish are you using?
Universal LNBF will pickup all transponders on PAS9
Can't get TwinhanDTV pci card to work
