I'm basically still having the same problem as before, but I've been able to get the Sat A signals a little stronger (~75) by making the pole a bit more level--but only on the upper end even-numbered transponders. The lower numbered transponders, as well as the odd-numbered ones, are still at 0. Sat. C is solid around 95 signal strength on all transponders. Should I ignore Sat C and just try aiming for Sat A?
I have a WNC triple-feed, multi-satellite LNB on the dish. It has a built-in multi-switch. I don't see how I can remove that. I removed some screws, but it didn't look like the multi-switch will come off. Or did you mean removing another multi-switch down the line? I had one on the old system, but the RG-6 cables are now running straight from the multi-switch on the triple-LNB unit to the receiver.
I've only got the basic programming package so far. I'm waiting for my Sony HD200 to arrive before I subscribe to the HD package. I'm using my old Sony SAT-T60 Tivo receiver to set up the elliptical dish.
Thanks again.
--Mike
