Stuck on channel 100??? | SatelliteGuys.US
Chuck In Ohio
52
Athens, Ohio
I turned on the tv & receiver this morning and intending to go to channel 10, I apparently pressed one too many zeros. I ended up on channel 100 where a message automatically popped up saying "downloading interactive menu" or something like that. The screen went black and that was the end of my tv viewing. I tried everything I could think of with the remote. I should mention that this is "tv2". Should I reboot my main box?
Thanks!
RaymondG@Dish Network said:
When this happens you can usually exit by pressing cancel. If that doesn't work you can press Menu-1 to get back to the guide to select another channel.
Isn't it simple by just pressing the guide button on the remote
Local HD channel PQ question
Bad spots in HD DVR recordings
