Stuck On One Station!!!! | SatelliteGuys.US
rasslick
14
hi all ... i have a few issues 1) my directv dvr that i just purchase in may is freezing up..i'll be pressing the remove button to change the station & all i am seeing i just the channel chaning on the screen but still on the same station.
2) it will not record anymore if i set it or press record..
3) i press the red "reset" button ..it works for a while then once i try to change the channel agin it freezes again will not change ...
i call directv spoke to rep he said i have to reprogramm the box & i all recording i did will be lost ...ok so i reprogramm the box & i am still getting the same errors....this is frustrating !!!!!!.... call tech support again reprogramm again!!!..start watch tv ,try changing satation...same thing!!!! can't record nothing
Same as me...
I had the same issues. Freezing. Non-recording. Daily restarts. One reset actually nuked all the shows on my hard drive...GRRRRRRRR!
After SEVERAL calls they FINALLY agreed to send me a replacement unit (a refurbished R15-500 to replace my smaller, crappier R15). I'll let you know if this unit is any better!
OTA Antenna Understanding?
Will Voom ever be carried on DirecTV ?
