Stupid 811 remote question | SatelliteGuys.US
thebradybunch
47
I just bought a new receiver and am trying to get evrything set up. I know there is a way to set the volume on the remote to control the volume of the amp no matter which setting or mode the remote is in. The problem is I do not remember how and it is not in the owners manual. Thanks for your help
Set up the AUX button for your amp. It's on page 69 of my manual - "Control a tuner or amplifier". Next page shows how to set the volume control.
Yes I think if they want to put it there fine, but it should be also at the beginning of the appendix for codes(how to program the remote).:rolleyes:
I have a Sony home theater reciever(or whatever you call it), and thats what I have all my sound going through, including the TV.
I've tried programming the 811 remote to it, so that I can control the volume to it, but none of the codes work, and when I do the search thing, it never works for it either :(
I wish there was some way to get the remote to work for it, just so that I can control the volume.....
There is also an option for scanning for devices not listed. Thats how mine found the Panasonic receiver.
HDNet Hockey - Local Blackout?
installation
